August 7, 2019 at 9:52 am
Shuvadeep
SubscriberHello vganore,
I am trying to compile the udf of motion. But error pops up each time. It shows
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).nnThe system cannot find the file specified.
nnD:Flapping Wing Simulationsmoving mesh Piezofan simulationTest1MMPiezoFan_filesdp0FFFFluentlibudfwin643ddp_hostlibudf.dll
Error Object: #f
#include "udf.h"
DEFINE_CG_MOTION (rotational_motion, dt, cg_vel, cg omega, time, dtime)
Domain *d =Get Domain(1);
Thread *t_object = Lookup_Thread(d, 2);
real moment [ND_ND], cg[ND_ND], force [ND_ND];
Compute_Force_And_Moment(d, t_object, cg, force, moment, TRUE)
real moment_z= moment [3]; * To compute the moment at the beginning of the time step and feed into the equation of motion */
real i1 = exp(-0.823*time);
real i2 = cos (8.19*time);
real i3 = 48870 sin(8.19*time);
real i4 = 2.893 pow(10,-
real omega = -i4 * moment_z * i1 * (i2-i3);
cg_vel[0]=0.0;
cg_vel [1]=0.0;
cg_ve1[2]=0.0;
cg omega [0]-0.0 ;
cg omega (1)-0.0;
cg omega [2]=real omega;
Fluent version is 18.2 and VS 2015.
Please help!
DrAmine
Ansys EmployeeAre you able to compile other UDFs?
August 7, 2019 at 11:13 am
Shuvadeep
Subscriberno
August 7, 2019 at 12:33 pm
DrAmine
Ansys EmployeeSo you have compiler problem. Can you go to VS command prompt x86_x64 and launch Fluent from that prompt and compile a dummy udf.
August 7, 2019 at 12:40 pm
Shuvadeep
SubscriberTried that also. Not working
August 8, 2019 at 4:49 pm
DrAmine
Ansys EmployeeCan you type cl to check?
Have you checked compiler threads under our installation subgroup? -
October 4, 2020 at 3:53 am
Joe001
Subscribergot the same issue.n
- The topic ‘UDF for CG Motion cannot be loaded’ is closed to new replies.
5859
