January 12, 2020 at 12:55 pm
elsaeed
SubscriberI want to simulate an energy source term describe the solidification and melting process of phase change material encapsulated in spherical capsules and packed in a thermocline tank.
January 12, 2020 at 12:57 pm
elsaeed
Subscriberthe term source is  s= - d((1-phi)*rho* DELTA H))/dt,Â
January 12, 2020 at 1:07 pm
January 13, 2020 at 10:29 am
Forum ModeratorWhat's the question? Source terms are covered in the UDF manual.Â
January 13, 2020 at 6:06 pm
elsaeed
SubscriberWHEN I ENTER THE SOURCE TERM OF THE LATENT HEAT THE TEMPERATURE DISTRIBUTION NO CHANGED, IT MUST BE INCREASED TO A CERTAIN VALUE AND THEN REMAINS CONSTANT DURING PHASE CHANGE PROCESS AND FINALLY INCREASED. BUT WHEN ENTER THIS UDF SOURCE THERE IS NO DIFFERENCE IN TEMPERATURE DISTRIBUTION. WHY?
January 13, 2020 at 6:09 pm
elsaeed
SubscriberSOURCE TERM OF LATENT HEAT WHICH DESCRIBE THE MELTING AND SOLIDIFICATION PROCESS OF ENCAPSULATED PHASE CHANGE MATERIAL INSIDE THERMOCLINE TANK.Â
January 13, 2020 at 6:18 pm
elsaeed
Subscriber s= - d((1-phi)*rho* DELTA H))/dt,Â
phi IS the porosity of the packed bed,
rho is the solid density of pcm,
DELTA H is the latent heat content which is a function of temperature which is varies with time
dt is the physical time step
so, HOW can I write this udf source correctly?
January 14, 2020 at 6:09 am
Amine Ben Hadj Ali
Ansys EmployeeEdit moving to fluid. -
January 14, 2020 at 6:13 am
Amine Ben Hadj Ali
Ansys EmployeeDid you check customization Manual as well as the melting solidification model?
- The topic ‘UDF’ is closed to new replies.
4683
1565
1386
1242
