    • fatima Zmim
      Hellow everyone I want to simulat water temperature insid cylidre (3D). This cylindre insid box with user defined function . But I have the divergence probleme for temperature.  when i start my simulation i recieved message "Turbulence velocity limited to viscosity ratio of 1000000e+05). I try to run calculat with application boundary condition (convection and radiation ) without using UDF i noticed computational stabilization.
      iS it that he use "user defined function influence he calculation for fluid simulation ?
      So please help me to find another way to apply source without using user define function
      What does the UDF do? That's usually a good starting point for troubleshooting. The viscosity ratio warning can be ignored, but it's cause needs to be understood (clue, look at the flow field).
    • fatima Zmim
      thank you for your reply
    • fatima Zmim
      my problem is i find values does not make sense for temperature
      OK, but what does the UDF do? That'll guide us towards a solution.
Viewing 4 reply threads
  • The topic ‘UDF’ is closed to new replies.
