Electronics
Electronics
Two way coupling for Maxwell and thermal problem
    • q.qin
      I am doing simulations for a cryogenic motor. I want to do a two-way coupling for Maxwell 3D and thermal 3D. Due to the computational complexity, I want to use the university's HPC to solve it. However, I have no idea how I should write the sub file and/or the Python file for these coupling simulations, and what files I should submit to HPC. I am wondering if anyone has samples?
    • Ivonne Marti
      If the HPC cluster has a scheduler installed (e.g., RSM) and it's also installed on your machine, you can submit the job directly from the Electronics Desktop UI. To do this, go to the Simulation tab in the menu and:
      1. Select "Scheduler" – choose the scheduler you want to use.
      2. Select "Submit" – specify the model, HPC settings, and HPC machine name.
      3. Click "Submit Job" to run the simulation
      More detailed information can be found in Maxwell Help > High Performance Computing > Submitting a Job.
      If you want to submit the job using command line, please look in Maxwell Help > High Performance Computing > High Performance Computing (HPC) Integration > Command Line Information for Ansys EM Desktop Products
