two-phase co2 simulation in cfx
    • abbas
      Hello
      I am working on two-phase co2. In my study, Co2 as a supercritical enters into the vortex tube and there should be different phases. One in vapor co2 and other is liquid co2. In my RGP table, I generated two table, one for vapor and another for liquid. i know that there should be some liquid drop in the domain.
      According to the following link: I should choose vapor and liquid materials, as well as a homogeneous binary mixture to define saturation properties. (step 2)
      !EDIT: Removed LINK
      So, when I choose for example co2 vapor, co2 liquid and co2mix (homogeneous binary mixture), I define three fluids. What should I do?
    • DrAmine
      The binary mixture is not required as phase. It is just required to calculate saturation properties. Define only two phases.
    • abbas
      Thanks for your help.
      So, I should add CO2 liquid and CO2 vapor into the FLUID definition. So, how the saturate properties will be calculated?
      Best regards
      Abbas
    • DrAmine
      They will be calculated via the homogeneous binary mixture you created.
    • abbas
      Thanks for your help. Therefore, I shouldn't need to add homogeneous binary mixture in the fluid definition and the solver find the homogeneous binary mixture in the materials section? And I don't need to define it anywhere else?
      Best regards
      Abbas
    • DrAmine
      No you do not need it in the domain definition. You Need just to create it as explained int axial turbine stage tutorial.
    • zhangguojie2015
      Dear, sir, could you help me do a tutorial about the CO2 non-equilibrium? especially about the material defined.
    • zhangguojie2015
      Hello
      !EDIT: Removed LINK
      could you help me do a tutorial about the CO2 non-equilibrium? especially about the material defined. Thank you !
    • DrAmine
      Please create a new thread for your question. Check at first the axial turbine stage tutorial.
Viewing 8 reply threads
  • The topic ‘two-phase co2 simulation in cfx’ is closed to new replies.
