September 18, 2024 at 12:30 pm
September 18, 2024 at 1:44 pm
MirandaH
Ansys EmployeeYes, Maxwell allows complex setups involving multiple motions, you may need to ensure that all moving objects are physically separated from stationary objects and that a Band object encloses the moving parts to separate them from the stationary parts of the geometry.-
September 18, 2024 at 2:55 pm
ctunceroglu
SubscriberSo, for one projectile, can I analyze both how much it rises within the barrel and how much it moves along the barrel at the same time?
September 18, 2024 at 2:57 pm
ctunceroglu
SubscriberBecause I need to create a second band inside the barrel to see how much it rises, but in that case, the bands will intersect. If I create two half-cylinder bands inside the barrel, I’m not sure if I can perform both the rise and forward movement analysis for a single object.
September 18, 2024 at 6:32 pm
MirandaH
Ansys Employeeno, bands cannot overlap.
September 19, 2024 at 5:33 am
ctunceroglu
Subscribercan I define two motions without overlapping bands for a single solid object?
September 19, 2024 at 2:03 pm
MirandaH
Ansys EmployeeUnfortunately, no, each band does one motion, it could be rotation or translation.
September 19, 2024 at 2:38 pm
ctunceroglu
SubscriberThank you for your responses and for being patient with my questions.
5754
