February 18, 2023 at 9:03 pmJoshuah DavisSubscriber
Having trouble locating the tutorial file for Chapter 1: Introduction to Using ANSYS Fluent in ANSYS Workbench: Fluid Flow and Heat Transfer in a Mixing Elbow. Can you help me get this file?Â
February 20, 2023 at 1:12 amAtharv JoshiForum Moderator
Hi Joshuah Davis
This Forum is meant for queries related to Ansys Discovery product. Please post your queries regarding other Ansys products on the Ansys Customer Portal.
Thanks and RegardsÂ
- The topic ‘Tutorial File’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
599
591
565
366
