March 6, 2024 at 12:04 pm
jackzhe551
Subscriberturbulent+ laminar in an heat exchanger 2 channel .what can I do? can one channel set turbulent,another set laminar?how to set ?thx.
March 6, 2024 at 3:48 pm
Forum ModeratorYou can set cell zones as laminar - whole model is turbulent but it's not used if you change the cell zone setting.Â
March 7, 2024 at 1:17 am
jackzhe551
SubscriberWhat will happen if I set the whole turbulent model ? does it substantially influence the heat transfer? It's supposed to be hot - turbulent and cold - laminar. and I have set the velocity and calculated the reynold number is turbulent, will fluent system systemically set a laminar mode to the cold fluid?
March 7, 2024 at 10:35 am
Forum ModeratorIt's a switch that you need to make. If you run a zone as turbulent that's more-or-less laminar the result may not be as accurate, typically you may see more diffusion in a result.Â
March 9, 2024 at 5:23 am
jackzhe551
Subscriberin the heat exchanger design,1. How to set the dynamic physical properties of phase-change hydrogen? Can refprop be invoked, and how? Can you give a tutorial of a phase change heat transfer case? (hydrogen varies in temperature from 15K to 50K, while 15-33K is a liquid and above 33K is a gas) 2. Once the refprop is set, is the rest of the operation consistent with the non-phase conversion thermal operation process? What should I pay attention to?
March 11, 2024 at 9:57 am
Forum ModeratorPlease post new topics into new posts.Â
- The topic ‘turbulent +laminar in an heat exchanger 2 channel’ is closed to new replies.
5824
