TAGGED: ansys-designmodeler, meshing, turbogrid, wind-turbine
October 21, 2022 at 12:24 pm
Andoni Rodriguez
SubscriberHello everyone,
I am currently working on a wind turbine blade and would like to mesh it with Turbogrid. This has a cut-off trailing edge and a flat tip.
But when I want to import the geometry from DiesignModeler into Turbogrid I get the error message "Parameter out of bounds. Minimum distance s requested =2.56965 e-005".
My guess is that the dimensions of the cut-off trailing edge and the flat tip are so small relative to the entire domain that they are below the possible accuracy of Turbogrid/DesignModeler.
Any ideas on how to overcome this problem?I would be very grateful for any help.
Regards
November 1, 2022 at 10:59 pm
rfblumen
Ansys EmployeeIf this is an industrial sized wind turbine blade, it sounds like perhaps the cut-off trailing edge is resembling a sharp knife-edge. Some possible workarounds:
-Turn off the "Cut-off or Square" trailing edge definition in TurboGrid. Using a different topology for the trailing edge may avoid the error
-Try scaling up the geometry in DesignModeler by a reasonable value such that the mesh generates in TurboGrid. Scale the mesh back down in CFX-Pre.
-Modify the geometry in DesignModeler to avoid this knife edge (if that's what's causing the issue). Dimensions that small for such a large geometry aren't realistic
- The topic ‘TurboGrid ERROR. Minimum distance s’ is closed to new replies.
3597
1208
1092
1068
952
