September 23, 2019 at 4:27 am
feby1993
SubscriberhiÂ
how could we simulate tunnel ventilation any idea guys
September 23, 2019 at 11:36 am
Raef.Kobeissi
SubscriberYou needs to have a fluid domain that represents the tunnel and then you need a boundary which represents the fan inlet and another bc that represents the outlet (where air would escape from the tunnel). -
September 23, 2019 at 1:42 pm
feby1993
SubscriberAny examples mate
January 21, 2020 at 5:12 pm
praveen98
SubscriberI have the case of analyzing flow between two parallel cylinders . The outer cylinder is stationary and the inner cylinder will be rotating. Initially, the gap between the two cylinders is filled with fluid. And the fluid gets motion due to the rotation of inner cylinder.How can I simulate this to study the flow in ansys .
Myself being new to fluid simulation can you send some tutorial material sir.
January 21, 2020 at 5:17 pm
DrAmine
Ansys EmployeeCheck his YouTube channel. -
January 23, 2020 at 10:57 am
user deleted
SubscriberCheck his YouTube channel.
Unfortunately it is no longer available
January 23, 2020 at 10:59 am
DrAmine
Ansys Employeefound this tunnel video:Â
https://www.youtube.com/watch?v=4ZhsbKB2DpM
January 23, 2020 at 11:54 am
user deleted
Thank you very much. The message is a bit offtop, my topic is about SFdamper with elastic elements, so I need a lot of FSI calculations. And there have been a lot of very useful videos on Mr. Kobeissi channel.
January 23, 2020 at 2:35 pm
DrAmine
Ansys EmployeeOkay: then write him directly.Â
- The topic ‘tunnel ventilation’ is closed to new replies.
5864
