January 14, 2025 at 7:49 amOvidiu.FloriSubscriber
It's the first time when i'm trying to do transient structural analysis and i don't have experience with it.
I'm trying to setup a Transient structural analysis of a structure ( shock impulse ) 3 strikes consecutive at 100G at a time interval between them of 0.004 s and it works for the first 2 steps ( from 0 to 100 g and back to 0 ) but when the solver is trying to converge the second strike the error occured " The solver engine was unable to converge on a solution for the nonlinear problem as constrained " .
Can someone help me with that please?
January 14, 2025 at 8:12 amErik KostsonAnsys Employee
Hi
There are lots on this on the site and on internet See here (just search):
Hope the above gives some general tips, but
as you might be in contact with Ansys customer support allready, I would suggest to proceed there as we might need to look into your model (something/model review, that can not be done here in the forum).
All the best and I hope you resolve the issue soon.Thank you
Erik
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
1416
599
591
565
366
