Transient Structural ANSYS APDL Looping Code Problem
    • Audy Maulizar
      Dear all. I am having a little bit of trouble with setting up a looping transient structural analysis code. For the sake of brevity, I have put only the relevant block of code below.
      !---------------------------------Flutter Analysis Loop---------------------------------
      U_fin = 19 !m/s
      init_time = 5 !s
      final_time = 20 !s
      dt = 2.5E-02 !time step in seconds
      total_steps = (final_time-init_time)/dt
      *DO,i,1, total_steps, 1
          /PREP7
          [Element Modification Code Here]
          ALLSEL, ALL
          /SOLU
          time_val = init_time + i*dt
          ANTYPE,,RESTART
          AUTOTS, OFF
          DELTIM, dt
          TIMINT, ON
          OUTRES,ALL,20
          TIME, time_val
          SOLVE
          FINISH
      *ENDDO
      The general idea behind this looping section is to have ANSYS modify the properties of a structural element in every load step (as shown with the /PREP7 section) then solve the resulting new structural setup (as shown in /SOLU section). The problem I faced was that the DELTIM and TIME commands seem to not receive the values from the parameters "dt" and "time_val" respectively, regardless of how those parameters have been defined beforehand. This resulted in ANSYS returning to the default values for the time step sizes and time at the end of a load step.
      Anyone's help on this problem is very welcome.
    • mrife
      Hi Audy Maulizar
      The restart database contains the parameters as they are at the first substep of the first load step.  Use parsav and parres to save/resume the parameters within the loop.
      Also, I am getting a 'code smell' from the posted script and the "element modification code".  What exactly is going on here?
      Mike
      • Audy Maulizar
        Thank you for your answer Mike. The [Element Modification Code Here] is just a block of code I wrote to change the parameter values for the MATRIX27 elements. I omitted it from this post, because I figured it'd make the code too long for the troubleshooting purpose when it's the looping part that has problems. Here's a more complete version for your reference.
        U_fin = 19 !m/s
        init_time = 5 !s
        final_time = 20 !s
            /PREP7
            !Constant Coefficients
            rho = 1.225 ! air density kg/m^3
            B = 11.89 ! deck width
            Le = 15.24! element length
            Pi = 3.14159
            Uh = U_fin*dt/(final_time-init_time)
            init_freq = 0.19788713 ! Hz
            osi_freq_0 = init_freq
            ! flutter variables
            Ur = Uh/(osi_freq_0*B)
            omega_h = 2*Pi*osi_freq_0 ! radial natural frequency
            K_h = omega_h*B/Uh
            a_h = 0.5*rho*Uh*Uh*K_h*K_h*Le
            b_h = 0.5*rho*Uh*B*K_h*Le
            ! flutter derivatives
            A1 = vala1(Ur)
            A2 = vala2(Ur)
            A3 = vala3(Ur)
            A4 = vala4(Ur)
            A5 = vala5(Ur)
            A6 = vala6(Ur)
            H1 = valh1(Ur)
            H2 = valh2(Ur)
            H3 = valh3(Ur)
            H4 = valh4(Ur)
            H5 = valh5(Ur)
            H6 = valh6(Ur)
            P1 = valp1(Ur)
            P2 = valp2(Ur)
            P3 = valp3(Ur)
            P4 = valp4(Ur)
            P5 = valp5(Ur)
            P6 = valp6(Ur)
            r,900
            rmodif, 900, 14, -b_h*P5
            rmodif, 900, 15, -b_h*P1
            rmodif, 900, 16, -b_h*B*P2
            rmodif, 900, 26, -b_h*H5
            rmodif, 900, 27, -b_h*H1
            rmodif, 900, 28, -b_h*B*H2
            rmodif, 900, 38, -b_h*B*A5
            rmodif, 900, 39, -b_h*B*A1
            rmodif, 900, 40, -b_h*B*B*A2
            rmodif, 900, 92, -b_h*P5
            rmodif, 900, 93, -b_h*P1
            rmodif, 900, 94, -b_h*B*P2
            rmodif, 900, 104, -b_h*H5
            rmodif, 900, 105, -b_h*H1
            rmodif, 900, 106, -b_h*B*H2
            rmodif, 900, 116, -b_h*B*A5
            rmodif, 900, 117, -b_h*B*A1
            rmodif, 900, 118, -b_h*B*B*A2
            CMSEL, S, DampMatElement, ELEM
            EMODIF, ALL, REAL, 900
            r,901
            rmodif, 901, 14, -a_h*P6
            rmodif, 901, 15, -a_h*P4
            rmodif, 901, 16, -a_h*B*P3
            rmodif, 901, 26, -a_h*H6
            rmodif, 901, 27, -a_h*H4
            rmodif, 901, 28, -a_h*B*H3
            rmodif, 901, 38, -a_h*B*A6
            rmodif, 901, 39, -a_h*B*A4
            rmodif, 901, 40, -a_h*B*B*A3
            rmodif, 901, 92, -a_h*P6
            rmodif, 901, 93, -a_h*P4
            rmodif, 901, 94, -a_h*B*P3
            rmodif, 901, 104, -a_h*H6
            rmodif, 901, 105, -a_h*H4
            rmodif, 901, 106, -a_h*B*H3
            rmodif, 901, 116, -a_h*B*A6
            rmodif, 901, 117, -a_h*B*A4
            rmodif, 901, 118, -a_h*B*B*A3
            CMSEL, S, StiffMatElement, ELEM
            EMODIF, ALL, REAL, 901
            ALLSEL, ALL
            /SOLU
            ANTYPE,,RESTART
            AUTOTS, OFF
            DELTIM, dt
            TIMINT, ON
            OUTRES,ALL,20
            TIME, time_val
            SOLVE
            FINISH
        *ENDDO
    • dlooman
      It's possible you could change the matrix27 values in solution simplifying the analysis.  Worth a try anyway.
    • mrife
      Hi Audy Maulizar
      Dave Looman is right, defining a real constant can be done in the solution processor (as well as in the preprocessor).  And I don't see a reason in the script to have the emodif commands, so you don't need to exit out of the /solu processor.
      • Audy Maulizar
        By not having emodif command, I assume the RMODIF commands are already enough?
    • mrife
      Hi Audy
      By the script shown yes assuming that say the elements of component DampMatElement aleady were assigned the real constant (ID) 900.
Viewing 4 reply threads
