October 23, 2023 at 1:29 pm
October 23, 2023 at 1:55 pm
erik.kostson
Ansys EmployeeHi
See how to use base excitation with modal super position.
https://www.youtube.com/watch?v=EY5J1jd1EMk
All the best
October 24, 2023 at 7:27 am
murali
SubscriberHi, Thanks for the link. I still have few doubts, can a displacement initial condition be considered equivalent to base excitation??
Just to make my problem clear:
I need to find the transient response of a cantilever beam subject to a transverse initial displacement. The initial vel is zero. There is no force applied, only the initial displacement. But when I do the analysis I am not getting the result. I need to know how to introduce an initial condition. If it is not possible to get a solution without introducinga force, how do i do the simulation accurately?
October 24, 2023 at 7:32 am
erik.kostson
Ansys EmployeeHi
Can you explain what you mean with initial displacement - how does the function vs time look like?
All the best
Erik
October 24, 2023 at 7:35 am
murali
SubscriberI meant, just lifting the free end of the beam to, say a few mm, and then releasing it, so that it vibrates for a few seconds and comes back to rest. A typical damped vibration condition.
October 24, 2023 at 7:46 am
erik.kostson
Ansys EmployeeHi
Use full transient analysis instead of mode sup.
You can then use a 2 step analysis .
1st step: lift tip up
2nd step: release (by deactivate at this step - see here : /forum/forums/topic/disable-constraints-in-a-load-step/)
All the best
Erik
October 24, 2023 at 8:11 am
murali
SubscriberDear Erik,
Thanks a lot. I will try this.
Murali
October 24, 2023 at 8:14 am
erik.kostson
Ansys EmployeeHi
That works so you can do what you need.
All the best
Erik
October 24, 2023 at 11:25 am
murali
October 24, 2023 at 11:30 am
erik.kostson
Ansys EmployeeHi
So you need to have at least 10 time steps in one period to capture a free vibration. Ideally 20 steps per period.
So say the free vibration of interest is 10Hz, or T_period=0.1 s, then the time step in the analysis settings should be T/10 = 0.01 s at least or even better T/20 = 0.005 s (at least for the 2nd step when the free vibration occurs).
See here for more info (3 min.30 s mark – 6 minute mark in the below – time step discussion):
https://www.youtube.com/watch?v=DnfGaJgbXcw
All the best
Erik
October 24, 2023 at 11:57 am
October 24, 2023 at 12:11 pm
erik.kostson
Ansys EmployeeHi
Please see the transient courses for instance the one I sent and try and understand that.
Also make sure you understand the difference between Steps (You have 2 steps), and time step (which is dt in the time integration used of the equations of motion – I showed above how to determine that time step size ~ T_period/10). You can search this online and get lots of help that way.
The end time for step 1 could be say 1 s (does not matter since 1st step it is quasi-static movement of the tip up), and the 2nd dynamic step could be say 10 * T_period (T_per.=1/freq., freq.=12 Hz for you) so you want to see 10 periods of vibration say or more perhaps say 100*T_per., thus the end of that 2nd step is =
end of first step (say 1s) + 10*T_per.Leave also time integration on for both steps (makes steps dynamic so considering mass, damping and stiffness matrix so full dynamics equations of motion
Also the help manual contains info on the theory of transient dynamics.
So go through material on transient dynamics and linear dynamics.
All the best of luck.
Erik
October 24, 2023 at 12:18 pm
peteroznewman
SubscriberGood discussion!
October 24, 2023 at 1:11 pm
October 24, 2023 at 1:19 pm
erik.kostson
Ansys EmployeeHi
It is because of the deformation scale factor/menu - search for that for more info.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_sim/ds_Context_Toolbar.html%23ds_Context_Toolbar
If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
Hope that helps
Erik
October 24, 2023 at 1:53 pm
murali
SubscriberHello Erik and Peter,
Thanks a lot for the detailed explanation. The effort is much appreciated.
Murali
October 24, 2023 at 1:55 pm
erik.kostson
Ansys EmployeeHappy to help - closing this discussion as it might be useful for others that do similar analysis - if you have any other questions, please open up a new discussion.
Thank you
Erik
- The topic ‘Transient structural analysis with initial displacement in workbench’ is closed to new replies.
