Transient structural
    • dani.besednjak
      Can I use the NEQIT command in a Transient Structural analysis, or is there an equivalent command? When I try to use it, I get an error and the analisys wont start.
      Yes you can use the NEQIT command in a Transient Structural analysis, what number did you use with it?
      If you used a command
      NEQIT,1
      that could cause the solution to fail to converge.
      Use a number larger than 15. You can go over 100 if you need it.
      If you don't use the NEQIT command, the solution control uses 26 so forcing it to use 1 can usually break the ability of the solver to converge.
