June 9, 2021 at 9:02 am
Cpwtub
SubscriberDear All,
I want to model a tower and apply a time dependent load at the top of the tower in one direction.
I bring the load as a external table - So time with the load , then i have time steps and load at the certain time step.
Then apply this imported data as the load , which varies with the time.
To check this, I imported a load ( external file), but for the first case I did not change the load with the time step. And yes there are other ways to apply directly without tables. But i wanted to check first.
When I run the transient, it showed me a sinusoidal displacement at the top of the tower, where i apply the load table.
What can be the reason?, Why even the load does not change with the time step.
Following is the , time steps, load application, and the results (deformations)..
June 9, 2021 at 9:26 amCpwtub
SubscriberSorry for the duplicate, Well I wanted to delete one but could not.
June 9, 2021 at 11:17 amAshish Khemka
Please see if the following link is of help to you:
Regards Ashish Khemka
Viewing 2 reply threads- The topic ‘Transient analysis – ANSYS APDL’ is closed to new replies.
6234
