February 9, 2022 at 1:50 pm
Abhinav_Maurya
SubscriberSteps being followed:
(Before tracer injection)
1. Setup: realizable K-e, standard wall functions; Multiphase - VOF; Species transport: OFF
2. Side Inlet: Air (Vol. frac 0); Top Inlet: Water (Vol. frac 1)
Ran the simulation in steady state, obtained converged solution post 20000 iterations.
(During tracer injection) - Switched to Transient simulation
2. Side Inlet: Air (Vol. frac 0); Top Inlet: Water (Vol. frac 1 but tracer mass fraction = 1)
3. In the solution --> Controls --> Equation, Flow: Off, Volume Fraction: On, Turbulence: On, Tracer: On
(Post Tracer Injection)
[Method 1]
2. Side Inlet: Air (Vol. frac 0); Top Inlet: Water (Vol. frac 1 but tracer mass fraction = 0)
3. In the solution --> Controls --> Equation, Flow: On, Volume Fraction: On, Turbulence: On, Tracer: Off
[Method 2]
3. In the solution --> Controls --> Equation, Flow: On, Volume Fraction: On, Turbulence: On, Tracer: On
While following Method 1, tracer amount doesn't increase in tundish. However, if method 2 is followed, tracer amount increases.
P.S: When the simulation was performed using method 2 for the homogeneous phase, the simulation ran smoothly
February 9, 2022 at 2:22 pmRob
Forum ModeratorHow are you adding a tracer if species is off?
February 21, 2022 at 9:33 amAbhinav_Maurya
SubscriberCorrection: Species transport is on During tracer injection and Post tracer injection
February 21, 2022 at 12:43 pmRob
Forum ModeratorWhat's the difference between Method 1 & 2?
February 21, 2022 at 12:48 pmViewing 4 reply threads- The topic ‘Tracer amount keeps on increasing in the tundish during RTD calcuation for two phase flow’ is closed to new replies.
5884
1306
