September 3, 2021 at 12:02 pm
ozdmrdnz
Subscriberhello everyone,
Whats the difference between total deformation and directional deformation if we modeled simple midspan load beam. I expect these two thinks give us a same result because there is only Y direction force effecting our beam but its not workedÂ
cause I'am trying to set the model for sandwich structure, I just told you how I am try to think that model as simple as I can so that I gave a example for simple midspan beam
Best Regards
September 3, 2021 at 5:39 pmhesamkeshavarzz
SubscriberThey are the same only for Euler-bernoulli beam! neither for Timoshenko beam element nor solid elements.
September 4, 2021 at 6:19 amozdmrdnz
Subscriberthank you for your reply
Viewing 2 reply threads- The topic ‘Total deformation vs Directional Deformation’ is closed to new replies.
6550
1311
