May 21, 2024 at 4:51 pm
ssaeidab
SubscriberDear all,
I modeled a flux switching machine in Ansys Maxwell and need to obtain its Torque-speed curve. Can you please assist me with that and let me know how I can generate that curve using Maxwell?
Thanks
May 30, 2024 at 2:30 pm
GLUO
Ansys EmployeeHi,
In RMxprt you can right click Results>>Solution Data to access the curves. In Maxwell you need to create a variable as speed, and sweep it in parametric to get solution for all speed, then plot the curve.
GL
- The topic ‘Torque- speed curve’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
1510
1386
1209
