November 29, 2023 at 1:19 am
abankusomari
SubscriberHi to everyone .I am new to the ansys maxwell and i need clarity so i dont generate wrong results in my analysis.Please how can i plot the radial and tangential flux density for both inner and outer air gap for a magnetic gear.And also how can i plot the harmonics distribution at both the inner and outer air gap .like the figure below
Please how is the angular velocity applied to the inner rotor and outer rotor of the magnetic gear?what is the difference between the moving torque generated in ansys and the torque assigned to both inner and outer rotor.
November 30, 2023 at 3:14 pm
HDLI
Ansys EmployeeHello Ebenezer,
   1). Please use field calculator to calculate radial and tangetial flux density, and then plot them.
      Like Vec : ToCylindrical(
,offset<0mm, 0mm, 0mm>), use Vector -> XForm -> To Cylindrical, to convert Cartesian to Cylindrical coordinate. Â Â Â 2). When using one motion for both, moving.torque is for both.
HDLI
December 2, 2023 at 3:25 pm
abankusomari
SubscriberThank you Sir for the swift response but my questions were partially answered .
- The topic ‘torque and flux analysis of magnetic gears’ is closed to new replies.
3792
1388
1188
1095
1015
