3D Design
3D Design
Top View Direction Z(SpaceClaim Default)
    • Don Lewis
      If Z is the spaceclaim default; Why does every new installation switch to Y?
    • Devendra Badgujar
      Hi Don Lewis
      Let me check and get back to you on this.
    • Devendra Badgujar
      Hi Don Lewis
      If you go to File > SpaceClaim Options > Advanced, you can change the Top View Direction. (this will apply to all new documents, not the current SpaceClaim design).
      See attached screenshot for the option I am referring to.
      Top view direction: Allows you to change the top view to Z, Y, or X. This setting is saved with the document and only applies to new documents. You may want to change this setting when you import drawings from other CAD applications that use a different upward direction.
      This option is automatically set to Y when you run SpaceClaim with an Ansys license, giving your design the same orientation in SpaceClaim and Ansys. Choose X when you need to comply with manufacturing conventions.
      Regards.
    • Don Lewis
      The question wasn't how, but why do I have to.
    • Devendra Badgujar
      Hi Don Lewis
      Ansys by default sets this option to Y in SpaceClaim for every new installation. This is done to give the design the same orientation in SpaceClaim and Ansys.
      Regards.
Viewing 4 reply threads
  • The topic ‘Top View Direction Z(SpaceClaim Default)’ is closed to new replies.
