May 11, 2021 at 10:47 am
mnjja
SubscriberHad set-up a motoring (No combustion) simulation in Forte using forte sector mesh generator that runs fine, but once crevice model option is active (to best represent experimental condition) time-step error occurs and the simulation stops. Tried adjusting the tolerances but still get error.
I have tried changing the tolerance in Simulation Controlschemistry solver, still not resolved
Error : Run aborting because the timestep is being driven too small.
Error : Consider adjusting the timestep control tolerances according to cause of the timestep being too small.
How do I resolve this ?
May 13, 2021 at 3:50 pmRK
Ansys EmployeeHello,
Here are a few suggestions :
Make sure the geometry orientation is in alignment with typical engine model setup
For time step settings, make sure to try with the default values first, If large values are used, piston would sweep more than one cell in one time step, leading to such errors.
Also please note : When using theCrevice model, you cannot also include the crevice block in the Sector Mesh Generator
April 4, 2022 at 9:09 pmNang
SubscriberBonsoir moi ├®galement je rencontre ce probl├¿me sur forte, j'ai essay├® ces solutions, mais le pas temps est toujours petit je ne sais plus quoi faire.
Viewing 2 reply threads- The topic ‘Time-step driven too small error: Forte’ is closed to new replies.
2863
970
851
599
591
