Time required to run fluent simulation
    • scabo
      Hi
      I am trying to calculate the CPU time that it takes for running fluent simulations on HPC. I have 2 meshes one fine and one coarse, i want to calculate the time it takes to run the same problem on the 2 meshes and compare. How can i do that?
      thanks
    • Federico
      you can use the following TUI command: parallel/timer/usage
    • scabo
      Do I need to set this command in the journal file while submitting the job on HPC? And the after the simulation has run should i open the dat file in fluent and use the same command on the console?
      • Federico
        Yes, you can use this command in the end of your journal (before closing Fluent) and it will print out the details in the transcript (.trn) associated with the run.
    • scabo
      Okay will check it-thanks
