December 6, 2019 at 11:26 pm
xiaojiangyou
SubscriberHi,
I'm running a transient heat transfer process in ANSYS TRANSIENT THERMAL module. Is it possible to get the time history of the averaged temperature over a surface?Â
Thanks so much for your time and efforts!
Best
Xiaojiangyou
December 7, 2019 at 1:29 am
December 7, 2019 at 1:43 am
December 7, 2019 at 3:19 am
peteroznewman
SubscriberAverage was added to all results in one of the recent versions of ANSYS. You don't have it in your version. Can you upgrade to the latest version of ANSYS?
December 7, 2019 at 4:18 pm
xiaojiangyou
SubscriberThanks so much again. I'll try update to the latest version.
Besides, I'm also wondering is there a way to output the time history of each node temperature on that surface? I probably want to weighted average to that surface in the future.
December 7, 2019 at 8:32 pm
peteroznewman
SubscriberYou can Export the temperature of every node on the face at any specific time of the solution by right click on the Temperature result and selecting Export.
I know it is possible to write APDL code in a Command object in the Solution branch that will cause a file to be written with every time step, but I don't know the APDL commands myself. Perhaps someone else can provide that.
December 7, 2019 at 8:57 pm
xiaojiangyou
SubscriberI see. Thanks so much!
- The topic ‘time history of temperature averaged across a surface in transient thermal’ is closed to new replies.
6319
