September 27, 2017 at 11:19 am
admin
Ansys EmployeeFor getting time averaged values of UDMs (User Defined Memories) or UDSs (User Defined Scalars) do the following: 1)Define one or more UDMs 2)Create a Custom Field Function with CFF = UDM 3)Activate Fluent transient 4)In the solution panel activate "Data Sampling for Time Statistics" and in the Sampling Options select the CFF. After the run the time averaged CFF can be postprocessed as unsteady statistics in the Postprocessing menus. For time averaging an UDS an additional UDF has to be written. In the UDF the UDS has to be transferred to an UDM. Please refer to the Fluent Customization Manual for further information. Related solutions: 2041742: How to calculate time-integrated quantities from a transient solution in ANSYS Fluent? 2042394: How are the Unsteady Statistics (Mean & RMSE) evaluated when using Transient Data Sampling in ANSYS Fluent?
admin
Ansys EmployeeHow to do a time averaged Postprocessing of own variables?
- The topic ‘Time averaged Postprocessing of own variables’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
