September 16, 2024 at 7:07 pm
pdsamuel
SubscriberHello, I have been trying to use tiebreak contact (CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TOSURFACE_TIEBREAK) [Option 9] with the 20 noded Hexahedral solid element (ELFORM 23). When I select the surfaces using the segment set approach- it keeps giving me an error that certain master, slave surfaces have not been not found. Because this didn't work, I then tried defining tiebreak contact using the PARTIDs. But, with this approach the nodes on the middle of the edges don't get selected and only the nodes on the corners are tied. I strongly prefer to use the segment set selection of tiebreak surfaces, and need to know to how to execute this for the 20 noded hexahedral elements.
Also another associated issue is that when I use a regular a contact definition between two hex elements and apply a closing/compressive load, there is interpenetration at the middle nodes (i.e. the nodes in the middle of the edge)- which should not occur.
Can anyone share from LSDYNA support/community help figure a solution to these problems? Thanks
September 23, 2024 at 10:46 pm
Reno Genest
Ansys EmployeeHello,
Which version of LS-DYNA are you using? Could you post images showing the problem?
Reno.
October 4, 2024 at 4:11 pm
October 4, 2024 at 4:14 pm
October 4, 2024 at 5:23 pm
Reno Genest
Could you send your test model to your Ansys account manager? He will forward it to me and I will have a look.
Thanks,
Reno.
November 4, 2025 at 4:46 pm
pdsamuel
SubscriberHello Reno Genest, What is the correspondence email to send the model to you? Additionally, I am facing a different problem when using the 20 Hexahedral elements. Of late I have been experiencing the error as "negative determinant, check element connectivity' using these 20 Hex elements. Please help. Thank you!
November 4, 2025 at 5:11 pm
Reno Genest
Please contact your Ansys account manager to send us the model. What is the name of your organization?
Also, note that Ansys employees are not allowed to upload and download files on the Ansys Forum.
Let me know how it goes.
Reno.
4708
1565
1386
1242
