September 19, 2023 at 6:41 am
BALA
SubscriberHi All,
I am having three plate which joined or holded by a single bolt as shown in figure, in case if i want to use a beam connection or fixed joint then how can i connect these plate three using these coonection. as far as i know we can connect two plate easily, can we select two surface or curves in mobile scope .
September 21, 2023 at 12:36 pm
Ashish Khemka
Forum ModeratorHi,
Via beam connection or a fixed joint constraint top and bottom plates. Let the center plate be held by friction and if needed define cylindrical constraint in the hole through which the bolt passes.
Ashish Kumar
September 22, 2023 at 2:06 pm
BALA
SubscriberThanks for your reply, here that one bolt is holding all these three plate and applying Random vibration PSD profile so i cant use frictional contact.
September 22, 2023 at 2:15 pm
Ashish Khemka
Forum ModeratorThanks for the update. At the bolt-hole location for the three plates, you can define a fixed support and then apply base excitation to the fixed support.
How to Perform Random Vibration Analysis | Ansys Courses
Ashish Kumar
September 25, 2023 at 5:11 am
BALA
SubscriberThanks. Actually these plates are small part of one big assembly where frxed support is at different loacation so i cant keep bolt bolt hole as a fixed support, keeping bolt as solid may work but again i cant give any nonlinear contact so thats why i am not using it i just trying to figure out how can i connect these three plates using one beam connection because in actual case they are held by one bolt.
- The topic ‘Three plate joint using single bolt – how to connect using beam connection’ is closed to new replies.
5824
