December 2, 2021 at 9:04 am
mbanaei
SubscriberHi
I have also faced the same problem. I have renamed all the dll files listed above but I get a new error when I want to use FLUENT meshing. I get this error:
License Error
This version of Fluent supports only Watertight Geometry workflow.
Fluent will exit.
How can I solve this issue?
Thanks Mohammad Banaei
December 2, 2021 at 12:22 pm
System
SubscriberThis discussion was created from comments split from: solution to procedure entry point error pow2o3. -
December 2, 2021 at 3:24 pm
Forum ModeratorWhich version of Fluent are you using? The watertight geometry workflow is licenced with the software, so if you can open Fluent Meshing there shouldn't be anything stopping it working, unless you exceed the cell count. What licence are you using?
- The topic ‘This version of Fluent supports only Watertight Geometry workflow’ is closed to new replies.
Ansys Innovation Space
1414
1256
1118
1015
