December 11, 2024 at 6:36 pm
December 12, 2024 at 1:17 am
peteroznewman
SubscriberOpen the solid body tube in SpaceClaim and use the Midsurface tool on the Prepare tab. Then the solid body that meshed very ill with solid elements will be replaced with a midsurface with an assigned thickness that will mesh very well with shell elements.
December 13, 2024 at 9:53 am
biwako
SubscriberDear Peter, thank you very much for your reply. It was very helpful to me. It simplified my 3D model and sped up the meshing. But the mesh result is still wrinkled. I don't know where it comes from, because the mesh parameters setting is the original one. My tube is slightly tapered, because it is a fishing rod. Do you think this is the cause of the problem? Brgds,
December 13, 2024 at 3:08 pm
peteroznewman
SubscriberThe element size is too large. Where is shows 20 mm use 5 mm. On the Resolution line where it says 2 use 4.  Smaller elements and higher resolution will smooth out the mesh.
5694
1891
1419
