February 21, 2023 at 7:26 pm
irfan.sc19b048
SubscriberDear sir, i am doing simulation of circular plate which is clamped at its boundary. After that i give pressure load to the plate. i want to find the thickness of plate after deformation of plate along its diameter.
February 22, 2023 at 8:45 pm
Andreas Koutras
Ansys EmployeeHello, what element type are you using, solid, shell, or thick shell? If you use solids or tshells you can determine the plate thickness by recording the displacement of nodes at the top and bottom surface through *DATABASE_NODOUT. Alternatively, Element Tools > Measure can be used to measure distance between two nodes and to also plot its time history.
- The topic ‘thickness variation’ is closed to new replies.
1890
1419
1304
