August 21, 2024 at 12:09 pm
paul.lardet
SubscriberDear all,
I use Ansys Mechanical 2024 inside Workbench to model thermal problems.
Mechanical APDL has a capability to model radiation between the pair of faces of a thermal contact (see 7.1.6 in the documentation)
Do you know if this functionnality is available in any way in workbench mechanical UI ?
Best regards,
Paul
August 22, 2024 at 8:40 am
Deepak
Ansys EmployeeHiÂ
Refer to this knowledge material: Modeling Radiative Heat Transfer - Ansys Knowledge which demonstrates how to set up radiation heat transfer loading on the interior faces of two plates facing each other within Ansys Workbench Mechanical.
Deepak K.
August 23, 2024 at 7:39 am
paul.lardet
SubscriberHi Karri,
Thanks for your answer and the link. I could indeed use face-to-face radiation.
But in some case, I would prefer to use the contact tool, which is supposed to support radiative exchange (see APDL documentation).
This can be very usefull : no view-factor calculation (only local heat exchange), no geometrical gap needed between faces.
Any idea to activate this functionnality inside workbench mechanical ?
Paul
August 23, 2024 at 9:12 am
August 23, 2024 at 10:06 am
paul.lardet
SubscriberThanks for your informations.
Maybe it could be achieved indirectly by specifying a variable TCC, with a function of the temperature of the faces in contact ?
Do you know if these temperatures are accessible, and if variable TCC is enabled in the GUI ?
Paul
August 23, 2024 at 10:15 am
August 23, 2024 at 10:22 am
paul.lardet
SubscriberThanks for your explaination.
I undersand what is TCC and where it is specified.
Do you know if this parameter can be defined inside the GUI with a function or tabulation ? If yes, can this function depend on the face temperature ?
Paul
August 23, 2024 at 10:58 am
5899
1306
