September 8, 2024 at 4:10 am
deepesh.p.gurdasani
SubscriberCan I use input of temperature in heat energy (calories / joules) in thermal analysis? If not, any way around to convert from calories to degree celsius?Â
thanks in advance -
September 8, 2024 at 2:34 pm
peteroznewman
SubscriberPlease describe all the boundary conditions on an image of the geometry. Are you asking about a Steady State Thermal analysis or a Transient Thermal analysis?
You can convert calories to Joules, but where is that energy initially and where do you expect it to transfer to?
September 9, 2024 at 1:57 am
deepesh.p.gurdasani
SubscriberIts stead state thermal analysis. Calories can be converted to joules but I cant find a way to input joules as parameter. This energy is to be applied on a triangular block (example I am trying out). This energy will be transferred as convection to water as fluid around it.Â
September 10, 2024 at 7:17 pm
deepesh.p.gurdasani
SubscriberAny suggestions?Â
Thanks
5799
