November 21, 2024 at 3:07 am
kwg97
SubscriberHi.
I'm working on polyflow on workbench 2024 R1 and i got a error message that
'Update failed for the Solution Component in Fluid Flow(Polyflow).
The solver failed with a non-zero exit code of : 1 '
And i didn't get any methods for solving this issue
How to resolve this?
Thanks!
December 3, 2024 at 2:59 pm
Prashanth
Ansys EmployeeThe error message indicating a non-zero exit code of 1 typically means that the solver encountered an issue that prevented it from completing the solution process successfully. Ensure that the model setup, including the materials used, is correct. Incorrect setup can often lead to solver issues
