The solver engine was unable to converge on a solution for the nonlinear problem as constrained.
    • 17rt654
      Hello, based on the question above. What does my simulation have problems with?.
    • jonsoln
      Hi!nCheck the solution file to see what error caused the solver to fail. This will give you more information about what might be the issue. To open the solution file go to Solution information and select Solver output. Scroll down towards the bottom or search for Error.n
  • The topic ‘The solver engine was unable to converge on a solution for the nonlinear problem as constrained.’ is closed to new replies.
