October 27, 2021 at 12:41 pm
Guojun
SubscriberHello,
I am simulating a case using Fluent 2021R1 on my office computer (Windows system) and HPC(Linux system). However, when the same case was simulated on both system with turbulence model employed, the simulation results are very different. The below picture is the contours of liquid fraction on a surface.
October 27, 2021 at 1:37 pmRob
Forum ModeratorCan you check convergence and whether both are single/double precision. What is the mesh like at the interface as you're not getting liquid in the stationary zone either.
October 27, 2021 at 2:08 pmOctober 28, 2021 at 11:20 amRob
Forum ModeratorThat should give the same result. Can you post contours of velocity etc to see what else is going on? Has anyone else checked your model set up, and are you using any UDF code?
Viewing 3 reply threads- The topic ‘The simulation results obtained by Windows and Linux are different’ is closed to new replies.
5649
1885
1404
1303
