February 26, 2024 at 3:19 am
Wang Shaoqiang
SubscriberWhen I use maxwell 2023R2 for electromagnetic simulation modeling, the software reports Maxwell2d solver, process solver2d error: Internal Solver Error: 'Initial meshing failed! '. Please contact Ansys technical support. ", how can I solve or troubleshoot the problem
February 29, 2024 at 6:12 pm
GLUO
Ansys EmployeeHi,
I recommend updating Maxwell to 24R1 version. If the error persists, please double check if the boundary is correctly defined. You can also non-model some objects to find which part is causing this error.
GL
- The topic ‘The question of Maxwell2d solver, process solver2d error“Initial meshing failed”’ is closed to new replies.
1312
