March 13, 2020 at 5:12 pm
Jordan
SubscriberHi,
currently I am doing a simulation regarding to fuel cell (PEMFC) with 9 different parts combined together. I have successfully created my geometry in Design Modeler. However, I can't seem to mesh my design as it stated there 'the mesh generation was not successful'. I am currently using student edition ANSYS version 18.0. I don't came across with this problem when I am using version 18.1. Just I am curious what are the problems that I am facing now.Â
Details of my meshing:
Assembly meshing - Method : CutcellÂ
Relevance : 100
Sizing min : 0.1mm , max : 0.2mm
relevance center : Fine
Thank you.Â
March 13, 2020 at 5:22 pm
March 16, 2020 at 5:22 am
Keyur Kanade
Ansys EmployeePlease use latest version 202R1 and check meshing.Â
For cutcell, suggest you to go through documentation.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘the mesh generation was not successful.’ is closed to new replies.
6575
1311
