August 28, 2023 at 11:25 am
August 28, 2023 at 10:10 pm
Guilin Sun
Ansys EmployeeWIthout device configuration and simulation settings it is hard to know the cause. Please refer toÂ
Ansys Insight: Ansys Innovation Space–Forum and Feed and provide more details.
August 29, 2023 at 6:35 am
Soufiane El kabil
Subscriberthe wave is Plane in the Z-directionÂ
the BC is PML on all sides (2D)
a sample with 100 nmÂ
August 29, 2023 at 4:32 pm
Guilin Sun
Ansys EmployeeI do not know why you cannot post some screenshots. From your description it seems you used a plane wave source but used PML BCs. This is wrong since PML will truncate the plane wave causing diffraction.https://optics.ansys.com/hc/en-us/articles/360034382914-Understanding-the-diffracting-option-of-the-plane-wave-source
The correct way is to use periodic BC if it is normal incidence, or Bloch BC it is angled in xy plane since the propagation is along z axis.
August 30, 2023 at 8:23 am
Soufiane El kabil
Subscriber -
August 30, 2023 at 8:27 am
August 30, 2023 at 3:49 pm
Guilin Sun
Ansys EmployeeThank you. As I repiled previously, plane wave cannot be combined with PML. Please refer the link I gave.
If this is a periodic structure, please use periodic BCs in the periodic axes, or Bloch BC in the plane of angled source.
If this is a non periodic structure, and you want to use plane wave, please use TFSF:Â
Total-Field Scattered-Field (TFSF) source - Simulation object
Understanding source normalization in the TFSF source
Tips and best practices when using the FDTD TFSF source
Usually TFSF is not used to calculate transmission and reflection. If you have questions please write a new post.
August 31, 2023 at 8:56 am
Soufiane El kabil
SubscriberThank you for proviode for me some solution, but you should to know that The sample is infinite along x but it is not along y, where is semi infinite (no periodic), some other question, my Field must be along z, can you help me more to understand more why I can't use PML even the space between the edge of the sample and the monitor is so long .
August 31, 2023 at 3:40 pm
Guilin Sun
Ansys EmployeeYes, when x dimension is infinite and if it has no isolated nano objects you should use periodic BCs;
Finite sized y diraction should use PML.
For 2D simulation, you can set the source polarization angle 90 to excite Ez.
I would strongly suggest you to watch some videos:https://optics.ansys.com/hc/en-us/sections/360007813194-FDTD100-List-of-videos
to get more information.
September 1, 2023 at 8:14 am
Soufiane El kabil
SubscriberI use FDTD in Lumerical for 2D simulations, and I wonder why the simulations are limited to the x-y plane and not the x-z or y-z planes. If I want to conduct a 2D simulation in the x-z or z-y plane when the field is in the z-direction, how can I achieve this?
September 1, 2023 at 5:19 pm
Guilin Sun
Ansys EmployeeYes you are right, currently it is only in xy plane for 2D simulation. Temporarily a possible solution for other plane 2D simulation is to set the 3rd dimension only one cell in size and use periodic BCs in this dimension.Â
- The topic ‘the ligns in FDTD’ is closed to new replies.
