Ansys Products
Ansys Products
The HFSS license is not released after the calculation.
    • Yuriy Dr. Podoba
      I have a problem with the license for HFSS, when I put several calculation tasks in queue, it solves the first task, but for the next task in the queue it gives an error:
      After this error in ANSYS License Manager it shows that all licenses are busy, although no calculations are running at the time.
      It is (as far as I see) not the case if the next task is started manually (without putting it in to queue) after the theprevious calculation is finished.
      What could be the reason?
      Thanks in advance.
    • randyk
      Hi Dr Podoba,
      This is a known issue with AnsysEM 2022R2.
      Defect TFS 683937 was created to address the license release failures; when queuing interactive jobs.
      The issue will be addressed in the 2023R1 release.
      Additionally, there are plans to release a 2022R2.3 patch in the comming weeks.
      The workaround until that point is to not queue your interactive submissions.
      thanks
      Randy
    • Yuriy Dr. Podoba
      I have installed the patch (ANSYS_2022R2.03_WINX64)
      but the problem is still occurs as described, despite the fact that the problem is listed in "Issues Addressed" in the patch documentation.
      is there anything I should pay my attention to in settings or during the patch installation?
      thanks,
      Yuriy.
    • Yuriy Dr. Podoba
      any ideas what can be the reason?
      thanks.
    • randyk
      Hi Yuriy,
      I just tested with 2022R2.3 and functionallity was as expected.
      I had started the analysis on one project and queued the second behind it.
      As you can see below
      --> Open AEDT and projects in GUI
      13:00:42 (lmgrd) TIMESTAMP 11/9/2022
      13:02:55 (ansyslmd) OUT: "electronics_desktop" username@usermachine  [18820]
      13:03:47 (ansyslmd) OUT: "electronics3d_gui" username@usermachine  [11040]
      13:03:49 (ansyslmd) IN: "electronics3d_gui" username@usermachine  [11040]
      13:03:51 (ansyslmd) OUT: "electronics3d_gui" username@usermachine  [18820]
      -> Start analysis (while running, queued second analysis)
      13:08:56 (ansyslmd) OUT: "elec_solve_hfss" username@usermachine  [26892]
      13:08:56 (ansyslmd) OUT: "elec_solve_level2" username@usermachine  [26892]
      13:08:57 (ansyslmd) OUT: "elec_solve_level1" username@usermachine  [26892]
      13:08:57 (ansyslmd) OUT: "anshpc" username@usermachine  [26892] (6 licenses)
      -> First analysis completes and licensing returned
      13:10:54 (ansyslmd) IN: "elec_solve_hfss" username@usermachine  [26892]
      13:10:54 (ansyslmd) IN: "elec_solve_level2" username@usermachine  [26892]
      13:10:54 (ansyslmd) IN: "elec_solve_level1" username@usermachine  [26892]
      13:10:54 (ansyslmd) IN: "anshpc" username@usermachine  [26892] (6 licenses)
      -> Second analysis starts and licensing out
      13:10:56 (ansyslmd) OUT: "elec_solve_hfss" username@usermachine  [29944]
      13:10:57 (ansyslmd) OUT: "elec_solve_level2" username@usermachine  [29944]
      13:10:57 (ansyslmd) OUT: "elec_solve_level1" username@usermachine  [29944]
      13:10:57 (ansyslmd) OUT: "anshpc" username@usermachine  [29944] (6 licenses)
      ->Second analysis completes and licensing returns
      13:12:48 (ansyslmd) IN: "elec_solve_hfss" username@usermachine  [29944]
      13:12:48 (ansyslmd) IN: "elec_solve_level2" username@usermachine  [29944]
      13:12:48 (ansyslmd) IN: "elec_solve_level1" username@usermachine  [29944]
      13:12:48 (ansyslmd) IN: "anshpc" username@usermachine  [29944] (6 licenses)
      Are you seeing different behavior?
      Can you share a snippet of the license log -- replace the username and machinename as I have done?
      Confirm AEDT 2022 R2.3 is listed at top left of AEDT Desktop?
      thanks
      Randy
    • Yuriy Dr. Podoba
      Here what i see:
      17:19:32 (ansyslmd) OUT: "electronics_desktop" username@usermachine  [16772]
      17:20:36 (ansyslmd) OUT: "electronics3d_gui" username@usermachine  [16772]
      17:20:57 (ansyslmd) OUT: "elec_solve_hfss" username@usermachine  [18580]
      17:20:57 (ansyslmd) OUT: "elec_solve_level2" username@usermachine  [18580]
      17:20:57 (ansyslmd) OUT: "elec_solve_level1" username@usermachine  [18580]
      17:20:57 (ansyslmd) OUT: "anshpc" username@usermachine  [18580] (4 licenses)
      17:21:37 (ansyslmd) DENIED: "elec_solve_hfss" username@usermachine  [2980] (Licensed number of users already reached. (-4,342))
      17:21:39 (ansyslmd) DENIED: "elec_solve_hfss" username@usermachine  [4860] (Licensed number of users already reached. (-4,342))
      But i cannot confirm that AEDT 2022 R2.3 is listed at top left of AEDT Desktop:
      I see only R2
    • Yuriy Dr. Podoba
      Please pay attantion that in the description of the ANSYS_2022R2.03_WINX64.zip
      in the download center it is listed:
      "• Desktop: -waitforlicense now behaves correctly and will wait for unavailable licenses to become
      available during -batchsolve
      • Desktop: Enabling Queue All Simulations will now check out the correct licenses during queued
      simulations."
      Which are actually included in ELECTRONICS_2022R2_WINX64.zip and cannot be corrected by installing ANSYS_2022R2.03_WINX64.zip.
    • randyk
      You would install the ELECTRONICS_2022R2.03_WINX64.zip  patch for Ansys Electronics 2022R2
    • Yuriy Dr. Podoba
      yes I have, now everything is working.
Viewing 8 reply threads
  • The topic ‘The HFSS license is not released after the calculation.’ is closed to new replies.
