July 21, 2021 at 1:56 pm
tmduc264
SubscriberHi everybody,
I'm using Steady-State Thermal mix with Static Structural to analyze the hot bending. I've setted The Temerature for the "Plate" - 900 degrees Celsius, The Displacement (Y) for the "Press" - 90mm. The result show The max force reaction is 9.76e+006 (at max Derectional Deformation Y - 90mm). It's too large to the result I caculated before which without the Temperature 900 degrees Celsius (7.75e+006). In fact, it should be smaller. I don't know how to get the correct result and I've stucked with this for about a week. Could anyone help me to find the problem?
Sorry for my bad English. I'll try to improve it :((
July 21, 2021 at 2:04 pmJuly 22, 2021 at 12:48 amtmduc264
SubscriberHi ekostson Thank you very very much for your respond, I think it could work for me. I'll try your way when i have time
July 22, 2021 at 6:33 amErKo
Ansys EmployeeAll the best.
Erik
Viewing 3 reply threads- The topic ‘The analysis of Hot bending’ is closed to new replies.
5649
1885
1404
1303
