Photonics
Photonics
Tesselation error in Lumerical CHARGE
    • S Sehgal
      Using the CAD software, I created a structure of a truncated cone and imported this .stl file in charge. Now in charge, when I am trying to simulate, the simulation is not running and It is stopping at 5% tessellating. I also tried the simulation by reducing the max. edge length to 0.01 under the mesh setting in the charge solver.
    • Guilin Sun
      Not sure what your  truncated cone looks like. If it has round top tip, it might be a problem since it will need many more  tetrahedral grids. To resolve this, you may need to "cut" a little bit of the tip, say 5 nm.
      If there is any small long gap, it might also cause this issue.
      Adjusting the global mesh constraints or auto-refinement settings might help. More setting description can be found here https://optics.ansys.com/hc/en-us/articles/360034918633-CHARGE-solver-Simulation-object
  • The topic ‘Tesselation error in Lumerical CHARGE’ is closed to new replies.
