April 17, 2018 at 4:05 pm
deepmech.maurya
Subscriberhey hello
         i am meshing body and provide some sizing. When ti take more than 3 hour than i understand some problem is there.
So i want to terminate the mesh but mesh status box is without cancel button.
please suggest how to terminate otherwise i lost my whole set up as i did not save it before.
thank you
April 17, 2018 at 4:26 pm
raul.raghav
SubscriberI usually kill the meshing process from the task manager and it just shows the meshing process was terminated. None of the mesh settings change. I then reduce the sizing and start the meshing process again. I would suggest you do the same for your case but there is always a slight chance that things can go wrong (like Workbench crashing or some other process in Windows crashing). I would have faced such an extreme problem in 1 out of 100 times. Not sure if you would want to take the risk and try killing the process.
- The topic ‘terminate the mesh forcefully’ is closed to new replies.
6625
1311
