Ansys Free Student Software
Terminate the Fluent meshing forcefully.
    • AmrKaood2020
      please, help me to terminate the Fluent meshing forcefully during the meshing process.
      Thanks
      If CTRL+C doesn't work use the Task Manger to kill the process.
      • AmrKaood2020
        Thank you for your response.
        I can't write CTRL+C in console. Is there is another way instead of Task manager?
      Click in the TUI. Hold the Control Button and click C a few times. CTRL+C  it's a UNIX interrupt command. It may not work, but it's about the only way to break out of a frozen task.
      • AmrKaood2020
        Unfortunately, it did not work using CTRL+C. I used task manager, i will restart setup meshing from scratch ?.
  • The topic ‘Terminate the Fluent meshing forcefully.’ is closed to new replies.
