August 21, 2020 at 8:53 am
EffeF
SubscriberHi! nJust want to know which is the best method if I want to simulate the tensile test (iso 527, astm d638) with Ansys Workbench. I want to verify lab test (material: PVB). nThank you! n -
August 24, 2020 at 7:34 pm
Sai Deogekar
Ansys EmployeeHi,nThis appears to be a tensile test for plastic materials. I think a Static Structural analysis would be a good fit. You would need the proper material model, including the plastic data. And you would also need to turn on Large Deflection.nHope this helps,nSain
- The topic ‘Tensile test simulation’ is closed to new replies.
