April 30, 2020 at 2:12 am
Velocimetry
SubscriberI have a polypropylene material as follows:Â
http://web.rtpcompany.com/info/data/0100/RTP150A.pdf
The tensile strength is lower than flexural (bending) strength. These are measurements from experiments. I understand this means the material is not homogeneous. I have to use this polypropylene material in the geometry attached. Where there is a force load on one of the corners.Â
My questions here are:
1. How can I enter flexural modulus and tensile modulus in the engineering properties window?
2. While evaluating results, what type of Stress/ Strain should I use as a deciding paraemmter (vonmises or total stress/ strain etc.)
3. Lastly, which one would be the deciding factor? flexural strength or tensile strength?
- The topic ‘Tensile Strength vs Flexural Strength’ is closed to new replies.
6520
1310
