temperature variations in the steel coils during conjugate heat transfer
    • dnama20
      I am trying to simulate furnace in which steel coils are getting heated by air and radiation. I defined solids and fluid and used conjugate heat transfer. i am not able to see the temperature variations in the strel coil. i have assigned very low thermal conductivity in steel
      Channel Partner
      If you do a flux report on the steel-air wall what do you get? What about volume min/max for the steel temperature. Assuming a "normal" furnace temperature range of 300-2500K it's very easy to see no change in air or steel temperature simply because the plotted range is too wide.
