February 23, 2021 at 6:24 am
parveensahni
SubscriberHow to take a cut section across any view in ANSYS discovery live 2020R1 ?
February 23, 2021 at 7:58 am
Naresh Patre
Ansys EmployeeHello PARVEEN SAHNI
If you would like to take a cut section across the geometry, then you can create a plane or select any planar face and click the Section Mode option from Design tab.
If you would like to take cut section for displaying results, then you need to click the "Cut Plane" option from the simulation bar located at the bottom. You can select the plane to move/rotate it to required location.
February 23, 2021 at 12:49 pm
parveensahni
SubscriberThanks Naresh PatreÂ
- The topic ‘Taking cut-section view’ is closed to new replies.
1306
