September 21, 2023 at 10:36 pm
Jason Franzman
SubscriberIn student 2023R2 workbench there is an expert setting in system coupling that is called quasi-newton stabilization. However in the academic license 2022R2 there is no stabilization property present. Was this a just added recently? I am having issues with getting a hyper elastic material and a fluid to converge. I have watched all tutorials and none of them help with this issue. I know you can use damping and I have read that it should be added to the material? Any suggestions on either issue
September 22, 2023 at 9:49 am
Rahul
Ansys EmployeeHello Jason,
Yes, Q-N stabilization is a recent addition in v232 in WB. However, you can find it in standalone system coupling application. Please refer to the user guide for more information Quasi-Newton Solution Stabilization (ansys.com).
Hope this helps!
- The topic ‘system coupling missing expert property quasi-newton stabilization’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
