Preprocessing
Preprocessing
Sweep Mesh with manual thin and solid shell
    • AbelBerhanemeskel
      Hello Everyone,
      I was trying to model an I beam using the manual thin sweep method with solid shell element, but when I choose the manual thin option the sweep number division becomes inactive and shows one. I want three element per thickness, how can I increase the number of division? I have tried manual thin with a simple plate and it works just fine. I have sliced the beam into its sweepable form. Any Help would be greatly appreciated.
      Thanks
    • Keyur Kanade
      There are certain limitations with manual thin. nPlease check at nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • AbelBerhanemeskel
      Thanks, It can't handle a multi body part you have to divide it yourself.
  • The topic ‘Sweep Mesh with manual thin and solid shell’ is closed to new replies.
