November 20, 2024 at 3:40 am
20171437
SubscriberI modeled an IPMSM motor using Maxwell 2D and then imported the modeled motor into Simplorer to connect it to an inverter for SVPWM control. My goal was to implement dq-axis control, specifically controlling the current and current phase angle.
However, I'm having difficulty implementing the inverter in Simplorer. If anyone has experience with this process and could provide an explanation or example files, I would greatly appreciate it. Please feel free to reach out via email. ( 20171437@edu.hanbat.ac.kr )
December 5, 2024 at 8:35 pm
MirandaH
Ansys EmployeeHere is an example coming with installation. C:\Program Files\AnsysEM\v242\Win64\Examples\Twin Builder\Components\Interfaces\Maxwell\TR-TR
May 14, 2025 at 2:47 am
EdithMcConnell99
SubscriberÂ
@Geometry Vibes In Maxwell, use Maxwell 2D > Field Simulator > Setup Co-Simulation or export data into Simplorer Component. As long as the configuration is correct you need to ensure the correct connections: stator phases, rotor position feedback.
5639
1885
1403
1303
