September 28, 2020 at 7:35 pm
DoodlerD
SubscriberHi,
What would be the ideal way to mesh a bonded joint between two structural components using mid surfaces? (ANSYS WB 2014)
1. A gap with MPC elements and pinball radius (as shown) or
2. No gap and connected structural components
I believe the latter will increase mass and rigidity because of the mid surface mesh.
Thank you!
September 29, 2020 at 3:37 pmAshish Khemka
Forum ModeratornnUse MPC contact for bonded as much as possible unless overconstraints exist. It is-n? Ideal for shell-solid, shell-shell, and beam-shell contactsn? Interface with small gap/penetrationn? It avoids spurious frequencies for modal analysisn? Rather than modify the geometry to fill the gap, they cannbe accurately ignored when using MPC Contact or a fixednjoint.nRegards,nAshish KhemkanOctober 1, 2020 at 3:05 pmDoodlerD
SubscriberThank you for your advice, my sumulation was successful nViewing 2 reply threads- The topic ‘Surface to Surface Contact, Mid-Surface Mesh’ is closed to new replies.
5179
1838
1387
1249
